Two questions to WLC4402
rouven.heim
I've two questions to the WLC4202.
First: Does the WLC have an internal radius server like the autonomous APs or do I need to use an external radius server for authentication?
Second: When a guest access is used, does this WLAN can have an encryption like WPA/WPA2?
Greetings,
Rouven
George Stefanick
Yes, it does have a local radius on the controller but not very robust and is used more for small SOHO deployments.
You can set up the GUEST ssid with security or not.
