two SSID with two different IP ranges
pcfreak49
Level 7
Level 7
how can you configure two SSID with two different IP ranges on cisco 800 series
here is current running-config
6 Replies 6
dmantill
Level 11
Level 11
Use this example am attaching...
The trick is the radio interface configuration and the "bridge 1 route ip" and "bridge 1 protocol ieee" and so on depending on the ammount of vlans.
it is possible to interface vlan 1 not to use wireless only for the LAN connection, SSID would interface from vlan 20 and more make ssid
when I have the running-config currernt
Yes it is possible, just do not link it to the wireless interface dor that vlan.
I did it three SSID and have created a different subnet and each vlan on the 2.4GHz wireless I'm not sure you can too on 5GHz?
If your router have a different radio interface, then, yes, you can do it.
If it is in the same interface that you want to use 5.0 Ghz f then I dont think so,
WHat 800 unit are you using?
I have the 800 series that has two Cisco 2.4Ghz and 5Ghz frequencies
The 2.4GHZ is now I'm trying to find and that does not work with the 5GHz
