Tx mode Current consumption of Cisco 350 series card
swadesd
I want to know the range of current consumption of Cisco 350 series WLAN card in transmit mode. The data available online specify only the max. current consumption (450 mA) when it transmits at max power (100 mW), but does not indicate the current consumption when it transmits at a different power (say, 1 mW or 50 mW).
Please let me know if you have any measurement data on the above.
Swades
pradeepde
Level 5
Level 5
Cisco Aironet 350 Series Client Adapters
Typical Power Consumption (at 100 mW transmit power setting)
Transmit: 450 mA
Receive: 270 mA
Sleep mode: 15 mA
I guess u cannot determine the power consumption at the particular moment that is transmitting power consumption
I have those "typical" data from the Cisco data sheet. What I am looking for is the current consumption by the card when it transmits at a different power (say at 50mW). [I.e., say, I fix the output power at 50mW instead of 100mW. Then how much current the card will draw ?]
Thanks.
