UAT documents for Wireless LEAP ,EAP-TLS authentication
sansarav720e
Level 6
Level 6
Hi ALL ,
            I am implementing Cisco ACS 4.2.1.15 for wireless user authentication in our enterprise setup , As part of UAT document , i dont know what all to be covered in that UAT document ,
          My UAT document should hold for both EAP-TLS and LEAP authentication along with syslogging ,becoz i am using both LEAP ,EAP-TLS as a authentication method , any good document which hold all these and it should be good UAT document .
HTH Regards Santhosh Saravanan
dmantill
Level 11
Level 11
Ok so if what you need is a document that explains details for each authentication method.
Then look for  the cisco wireless lan security, then chapter 7 that is the one that explains each method with details.
