UDP broadcast traffic on port 4554 from Wireless Access Points
jpittavino1
I am seeing a lot of broadcast traffic coming from my AP541N-A-K9 access points at port 4554/UDP . I have 5 of these in a cluster. I cant seem to find anything in the manual in regards to this port traffic. Any help is apprecieted
5 Replies 5
Rasika Nayanajith
I found this reference for this. As per this it is used for "internal use"
https://www.cisco.com/assets/sol/sb/WAP561_Emulators/WAP561_Emulator_v1.0.4.4/device_info.html
Rasika
**** Pls rate all useful responses ****
Thank you for your response. Do you know what "internal use" is used for though? Right now my firewall is blocking the traffic. Unless I know why it is needed, I do not plan on allowing it. I would also like to possibly turn this off at the access point level to reduce my network traffic.
I've got this too on the WAP321. Any way to resolve this?
I was unable to find a way.
It seems to be related to 'Single Point Setup'. If this is disabled, there UDP traffic on port 4554 disappears.
(Btw, there is also traffic for Bonjour if it is enabled.)
