unable to access Cisco 1852i Wireless Access Point using Management IP
Gregory Forster
Good Morning,
       I have a Cisco 1852i wireless access point configured using mobility express. I am trying access the WebGUI of the device using the management IP, but I am unable to. I am able to SSH to the device using the management IP and I am able to ping it as well. I have checked in the CLI for any other possible IP addresses that might have been configured and I am not seeing anything that stands out. Below id the version of the firmware for the access point.
AP Running Image : 8.5.131.0
Primary Boot Image : 8.5.131.0
Backup Boot Image : 0.0.0.0
AP Image type : MOBILITY EXPRESS IMAGE
AP Configuration : MOBILITY EXPRESS CAPABLE
Mark Elsen
  - Some things to try in the configuration
  ip http server
  config network webmode enable
M.
Marce,
    I will try that and let you know
Marce,
      I just tried to add these 2 statements, the problem I have is there is no conf t or if I go to config it only allows for config ap Client-trace.
Now I configure this device using the Mobility Express WebGUI initially, but I can't get to that now and I do not know why.
 Ref : https://www.cisco.com/c/en/us/td/docs/wireless/access_point/mob_exp/85/user_guide/b_ME_User_Guide_85/getg_started.html#task_273F476C3AEA4F56B207CD62A80051E3
           - Have you tried these instructions  (step by step and or in detail)
 M.
