Unable to manage WLC using wired connection
Hi all,
I am currently able to manage my WLC AIR-CT3504 using wireless connection but not able to do so using wired connection even though i have ensured that i am using the same ip. I can ping the wlc ip but cannot access it when on wired connection.
7 Replies 7
Mark Elsen
 - What management method are you trying  , CLI or GUI , for each case post error returned. (?)
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Both CLI and GUI. I can access the WLC when on a wireless connection but not when on wired connection
             - What is the error or errors returned for each method ?
 M.
       Beauty and terror
      Just keep going
       No feeling is final
The error that i received when trying to access the wlc via ssh is " Network error: Connection timed out"
I also receive a Connection timed-out error when trying to access the wlc via GUI.
I can access the wlc via wireless without any issues but i can't access it via wired connection
 - Check the network-path between the client and the controller (e.g. ping) , make sure not intermediate devices are blocking the needed connectivity
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Scott Fella
If your wired ip is on one of the configured dynamic interfaces on your controller?  If so, that is blocked unless you enable it.
config network mgmt-via-dynamic-interface enable
-Scott
