Unable to upgrade WLC 5508 using 7.4 IOS
roycemathew
            while trying to push the new Software to a WLC i am getting error as mentioned.
(Cisco Controller) >transfer download path .
(Cisco Controller) >transfer download filename AIR-CT5500-K9-7-4-110-0.aes
(Cisco Controller) >transfer download start
Mode............................................. TFTP
Data Type........................................ Code
TFTP Server IP................................... x.x.x.x
TFTP Packet Timeout.............................. 6
TFTP Max Retries................................. 10
TFTP Path........................................ ./
TFTP Filename.................................... AIR-CT5500-K9-7-4-110-0.aes
This may take some time.
Are you sure you want to start? (y/N) y
TFTP Code transfer starting.
TFTP receive complete... extracting components.
Sanity check failed on file. The file was not downloaded completely!  --- > What does this mean
TFTP Failure while storing in flash! (0)
the Size of file matches with Cisco and i am not sure how to check the MD5 on this file.
ftp> put c:/Intel/AIR-CT5500-K9-7-4-110-0.aes
ftp: 119537036 bytes sent in 921.35Seconds 129.74Kbytes/sec.
MD5: 4f30835b2170487c77ac23362dc8587d
Can anyone suggest why we are getting this.
15 Replies 15
debug transfer all enable
