Hi I have an Aironet 1600 access point (model no. AIR-SAP1602I-E-K9).
I have got it working with the 2.4GHz interface, but I am trying to use both the 2.4GHz and 5GHz interfaces. The issue I have is on the SSID Manager page, the option for 'Radio1-802.11N5GHz' becomes unticked after clicking save.
I have also tried enabling the 5GHz interface on the summary page, but then the log gives this warning:
No SSID configured. Dot11Radio1 not started.
Is there any way to get this working? If I need to have a separate SSID for the 5GHz interface that would also be ok.
Edit: I have got it working! I had to go to the Encryption Manager page and make the 5GHz match the cipher setting which the 2.4GHz network was already using.
