UNDER SPECIFICATION RANGE FOR BRI 340
MAX
Community Member
My installation compose by 2 BRI340 (50mw) feeding a dish and a yagi directly connected without any extra RF cable. The optical distance between the equipment is 2 KM and there isn't any obstacles in the straight line. The signals I obtain on both radios are very poor and never I can go up over 1Mb of throughput. Moreover, on both sides, using full power (50mw) is worse than using 30mw. All equipment and antennas have been double-checked and all seems to be right. Any suggestion?
James Strong
Level 2
Level 2
How high from the ground and building are the antennas? You must be clear of the fresnel zone for proper operation.
MAX
Community Member
Yes, I'm aware of the Fresnel Zone. The Yagi is 3 or 4 meters from the ground, the Dish is 2 or 3 meters from the roof of the build high 15 metres. The Fresnel zone should be respected
Max
