unknown devices in Prime's unique clients report
tadnan001
Hello everyone,
1-When i generate a unique clients report on Prime, I do see lot of unknown devices beside the popular vendors apple, HP etc.
Is there a way i can find out what are those unknown vendors?
2-This report tells me about the vendor only - is there a way to break down further like whether the device is iphone or ipad etc ?
I will highly appreciate your support/help in this regard
Cheers
Tariq
Leo Laohoo
You can update the OUI individually or update the OUI using a bulk upgrade (I'd prefer bulk upgrade).
First, download the official OUI list (updated daily) from HERE.  Next, upload the file to Prime Infrastructure using THIS procedure.
Thanks Leo, it worked.
Can someone please answer Q-2 ?
Currently, no.
gohussai
Level 4
Level 4
You have to update the OUI individually.
Download it from
www.macvendorlookup.com/vendormacs-xml-download
