Unstable Wi-Fi connection
Hello!
In our network we use WLC 9800 with version 17.9.5 and AP C9130AXI-E. I have problem with unstable Wi-Fi connection in the user. I increased timeout:
But I see the user has unstable Wi-Fi connection:
What can you recommend in this case?
Thanks!
Mark Elsen
    - Have a checkup of the WLC 9800configuration with the CLI command show tech wireless and feed the output to : Wireless Config Analyzer
         (do not use simple show tech as input for this procedure)
   - Engage in full client debugging according to https://logadvisor.cisco.com/logadvisor/wireless/9800/9800ClientConnectivity , these debugs can be analyzed with Wireless Debug Analyzer
  - Outputs from the commands mentioned in https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/217738-monitor-catalyst-9800-kpis-key-performa.html#anc5 can also be useful
  - Make sure the wireless environment has been sufficiently tested (for coverage) with a Wireless Site Survey before placing the access points.
  - Consider moving on to 17.12.3 which is now 'the' advisory release
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hello!
I devided to open the case in Cisco TAC and it turned out that the problem was in Load balance. This function was enable. When I diseble Load balance the situation has improved.
Thank you for your help and involvement!
Leo Laohoo
And this is only happening to one user only, right?
First off, reboot the AP in question.
Next, what is the exact wireless NIC model and the exact driver of the wireless NIC?
If this wireless client moves to a different AP, does the issue "follow"?
