Upgrade Cisco 3850 LAN base to IP Base for evaluation
CSCO10821565
Can the Cisco 3850 LAN Base image be upgraded to IP Base image for evaluation period? I want to test WLC feature on it. Thanks!
Hi CSCO10821565,  you will need to purchase the license for the upgrade from LAN base image to IP Base. for further assistance please feel free to send me a message. hope this helps!
Ferdinand Guasque
fguasque@cisco.com
Hell....I have purchased the Cisco RTU License for Cisco 3650,can You please send Me here the required config/syntax to upgrade a license
(LAN base to IP Base)
Hello....I have purchased the Cisco RTU License for Cisco 3650,can You please send Me here the required config/syntax to upgrade a license
