Upgrade path for WCS
vancamt76
Level 2
Level 2
We are currently running version 4.2.62.0 on WCS and we are looking to upgrade. I've been searching for the proper upgrade path for this. I would like to go to 6.0 code. All the controllers will be upgraded to 5.2.178 once WCS has been upgraded. Please let me know the proper procedure.
Lucien Avramov
Level 11
Level 11
Upgrade directly to 6.0 from wcs 4.2.62.0.
You just need to run the 6.0 WCS installer and that will upgrade your 4.2 version.
Make a backup of your 4.2 database before running the upgrade, just in case.
You should read the release notes thoroughly when upgrading WCS (or a WLC, for that matter). Here's a link to the relevant section about being able to upgrade directly from 4.2.62.0. To perform the upgrade (once you have a good backup or two), you simply run the installer and follow the prompts.
http://www.cisco.com/en/US/docs/wireless/wcs/release/notes/WCS_RN6_0.html#wp44448
The Cisco WCS release must be the same or more recent than the controller software release. Upgrade the Cisco WCS first to prevent any unexpected problems. Cisco WCS supports database upgrades only from the following official Cisco WCS releases:
•4.2.62.0
•4.2.62.11
•4.2.81.0
•4.2.97.0
•4.2.110.0
•4.2.128.0
•5.1.64.0
•5.1.65.4
•5.2.110.0
•5.2.130.0
