Upgrade to WLAN 5508
tbulliard
Does anyone know if there is an upgrade path from the WLAN 4402 to WLAN 5508? OR A proceedure to get the AP's to join the new WLAN?
We currently are using a WLAN 4402-50 and have maxed it out. We are plannning on purchasing a 5508 with 250 licenses, but we have AP's in remote locations using HREAP and it would be very costly to re-visit each site.
Leo Laohoo
In the WLC 4400, go to All APs and click Details.  Choose the AP of your choice and go to High Availability.  Put the information of the WLC 5508 and click apply.
Alternatively, if you are tired of doing this on a per-AP basis you can go to Wireless > Access Points >  Radios > Global Configuration.  Under High Availability enter the information of the WLC 5508 and click apply.
