Bookmark
Subscribe
5594
Cisco 881w Wireless speed question
louisbohls
Is the max wireless speed on the cisco 881w 54mbps even though it has 802.11n hardware?  What about the 891w?
13 Replies 13
Surendra BG
Louis,
881W does support N speeds.. this needs extra configuration.. that is...
METHOD 1
THE SSID should be either OPEN AUTHENTICATION WITH NO ENCRYPTION WITH ALL MCS CHANNELS ENABLED.
OR
METHOD 2
THE SSID SHOULD USE WPA-2 Enterprize or WPA-2 PSK and AES as the encrtption WITH ALL MCS CHANNELS ENABLED..
Here is the link to do it..
http://www.cisco.com/en/US/docs/routers/access/800/860-880-890/software/configuration/guide/wlan_ps380_TSD_Products_Configuration_Guide_Chapter.html
***** WPA - TKIP will not yeild N speeds..
Lemme know if this answered your question.
Surendra
Please dont forget to rate the posts which answered your question or was helpfull..
Surendra BG
I only get 144Mbps instead of 270 +  on 881w router any thing I need to change, I have allready set my security at wap v2 AES
dot11 ssid Ownage
   vlan 1
   authentication open
   authentication key-management wpa version 2
   mbssid guest-mode
   wpa-psk ascii 7 03145A1F03032******
   information-element ssidl advertisement
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 10 mode ciphers aes-ccm
encryption vlan 1 mode ciphers aes-ccm
broadcast-key vlan 1 change 10
ssid Ownage
ssid ***********
mbssid
speed  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2.
m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
channel width 40-above
channel 2462
station-role root
Hi Prasanth,
With just G-Radio enabled, the maximum that we can get is around 144Mbps.. with A-Radio enabled we can get 270 or 300. I guess the speed what you are getting is pretty good using the G-Radio.
lemme know if this answered your question..
Surendra
Please dont forget to rate the posts which answered your question and mark it as answered or was helpfull
Surendra BG
so how would I know if i am using G radio or A, is their a setting that I need to change or the hardware comes is build that way.
the SSID are mapped to G-Radio from the snippet that you have posted..
Surendra
Surendra
Surendra BG
Do I have option to do this
ssid Ownage ==== Using Radio A/N  == 300Mbps   === Vlan 1
ssid Ownage 2 ==== Using Radio G === 54Mbps  ==== Vlan 10
Can i be able to seprate by vlan and radio type ?
VLAN mapping is for SSID not for Radio.. yes you can do that by mapping the SSID with Desired Radios..
Surendra
Surendra BG
So your config should look like this..
en
conf t
dott11 ssid Ownage
vlan 1
auth open
auth key-ma wpa ver 2
wpa-psk ascii
guest-mode
end
en
conf t
int dot11 1
ssid Ownage
no shut
end
en
conf t
dott11 ssid Ownage 2
vlan 10
auth open
auth key-ma wpa
wpa-psk ascii
guest-mode
end
en
conf t
int dot11 0
ssid Ownage 2
encryption vlan 10 mode ciphers tkip
no shut
end
The above configuration will resolve your issue..
Surendra
Surendra BG
Hi prashant,
It will great if you could reply to the post on the forum.. if i am not free some one will help you out by posting the answer.. and if you just have 1 radio then here is the config..
ssid Ownage ==== Using Radio G == 144 Mbps   === Vlan 1
en
conf t
dott11 ssid Ownage
vlan 1
auth open
wpa-psk ascii
mbssid guest-mode
end
en
conf t
int dot11 0
mbssid
ssid Ownage
no shut
end
en
conf t
vlan 10
auth open
auth key-ma wpa
wpa-psk ascii
mbssid guest-mode
end
en
conf t
int dot11 0
mbssid
ssid Ownage 2
no shut
end
en
conf t
int dot11 0.1
encap dot1Q 1
bridge-group 1
end
en
conf t
int dot11 0.10
encap dot1Q 10
bridge-group 10
end
en
conf t
int gig 0.1
encap dot1Q 1
bridge-group 1
end
en
conf t
int gig 0.10
encap dot1Q 10
bridge-group 10
end
Make sure all the interfaces are up by issueing the command "sh ip int br"
The above will help you!!
Surendra
Surendra BG
Surendra,
It's not very clear in what you've posted on how you're selecting the radio.  I used Cisco CP to configure the AP for a friends business and it's very feature poor in regards to the AP.
I'm trying to reconfigure his AP so that I enable to N and G access for various users who come through the office but CP doesn't offer radio options and seems to bind to the G radio by defacto.  Perhaps it's more configurable via the http interface, but I can't reach it from outside of the office.  I know the encryption has to be changed away from WEP in order to do N, but the radio binding's are cryptic.
Could you look at my config and give me some guidance on enabling the same SSID for both N and G?  If you could point out which commands are specific to VLAN and radio bindings so I can see what's going on, that'd be really wonderful!
dot11 ssid SGAP
   vlan 1
   authentication open
   guest-mode
dot11 network-map
bridge irb
no ip address
no ip route-cache
encryption vlan 1 key 1 size 40bit 0 transmit-key
encryption vlan 1 mode wep mandatory
ssid SGAP
speed  basic-1.0 basic-2.0 basic-5.5 basic-11.0 basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
packet max-retries 3 0 fail-threshold 100 500 priority 6 drop-packet
packet max-retries 3 0 fail-threshold 100 500 priority 7 drop-packet
packet speed  5.5 11.0 6.0 12.0 24.0 priority 6
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface GigabitEthernet0
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface BVI1
ip address dhcp client-id GigabitEthernet0
no ip route-cache
Thanks!
Bob Pierce
Hi Bob,
here is the config which wil give N speeds..
dot11 ssid SGAP
   vlan 1
   authentication open
   guest-mode
bridge irb
no ip address
no ip route-cache
ssid SGAP
Surendra
Surendra BG
Leo Laohoo
Whooops!  Someone deleted the post.
josephsarkis
I have a question. I have a Cisco 881G-V-K9 wireless router and I am getting very weak signal. I am using a PCTEL antenna to strengthen the signal. My question is do I need to connect the PCTEL anntenna to the 881G-V-K( router? If so how do you do it? The PCTEL part# is MPMB80621MPTC. It's a 806-960/1710-2170 MHZ, 5/7 dBi, Panal antenna
