01-22-2019 02:12 PM - edited 07-05-2021 09:44 AM
HI ,
please advise what the correct process is to upgrade the software on my 8510 wireless controller
what do I download or do I do a full upgrade
what is the implication when upgrading ( does all ap have to rejoin and upgrade all the images )
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.0.110.0
RTOS Version..................................... 8.0.110.0
Bootloader Version............................... 8.0.100.0
Emergency Image Version.......................... 8.0.100.0
Build Type....................................... DATA + WPS
System Name...................................... CONTROLLER
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1615
Redundancy Mode.................................. SSO
IP Address....................................... x.x.x.
IPv6 Address..................................... ::
System Up Time................................... 110 days 8 hrs 11 mins 8 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country............................... ZA - South Africa
Operating Environment............................ Commercial (10 to 35 C)
Internal Temp Alarm Limits....................... 10 to 38 C
Internal Temperature............................. +26 C
Fan Status....................................... OK
RAID Volume Status
Drive 0.......................................... Good
Drive 1.......................................... Good
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 7
Number of Active Clients......................... 1625
Burned-in MAC Address............................ F8:72:EA:67:92:40
Power Supply 1................................... Present, Off
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 6000
System Nas-Id.................................... Cisco_67:92:46
WLC MIC Certificate Types........................ SHA1/SHA2
01-22-2019 11:42 PM
You will need an outage window and yes APs will need to upgarde the new image form WLC as well.
If your WLC are in HA AP SSO mode, then do this:
1. Push the firmware upgrade to the active controller. The active controller will push the firmware to the hot standby controller;
2. DO NOT REBOOT;
3. Do an AP pre-download;
4. Once the pre-download is complete, reload the pairs.
more info here:
https://www.rogerperkin.co.uk/wireless/upgrade-cisco-5508-ha-wlc/
https://www.booches.nl/2017/02/cisco-wlc-ha-sso-upgrade/
Dont forget to rate helpful posts
01-24-2019 07:05 PM
This is correct.
The APs will reload therefore you need an outage window.
Download the image to the WLC and then do the pre-download to the APs. Once they all have it then its a reboot of the controller.
If you have N+1 config do to both controllers.
01-23-2019 12:51 AM
