Upgrading Autonomous to controller-based (AIR-SAP2602I)
I don't know if coul possible upgrade an SAP2602i Autonomous  access point to controller-based?
Thanks in advanced for your help.
Regards.
Leo Laohoo
Yes, it's very easy to convert an autonomous AP into controller-based.
All you need to do is download the controller-based recovery image (filename contains the "rcv"), copy the IOS into the AP and change the bootstring of the AP to boot the "rcv" file.
harvisin
Level 3
Level 3
