URGENT HELP
I have two cisco 1300 series bridge/access point,  i need to connect this two brigde with wireless connection, is there any guide for this, please
thank you
Amjad Abdullah
this should be helpful to you:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008054339e.shtml
this is also a list of all config examples that you may find useful:
http://www.cisco.com/en/US/products/ps5861/prod_configuration_examples_list.html
hope this helps.
Amjad
Rating useful replies is more useful than saying "Thank you"
maldehne
You can send the current show tech from both sides as well as the switches that are directly connected to both bridges and highlight the switchports connecting them to vierify if your configuration is correct or wrong.
Amjad Abdullah
Here is one more useful example:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008058f53e.shtml
