Use EOL APs
whyme
Community Member
Hey everyone, I wanna buy a used EOP Cisco AP (e.g WS-C3650-24PS-L) for my home network cuz I have low budget. Is it still safe to buy one of these after EOL or do you recommend another one?
3700 wont support EWC. For this AP model either you get a WLC or you run it in autonomous mode.
APs that supports EWC. And yes, to download software from Cisco you need Service contract or your login associated with some partner company.
7 Replies 7
whyme
Community Member
e.g Aironet 3700 Series Access Points
Good AP. Just keep in mind that Cisco AP have two mode: capwap mode or autonomous mode. If you buy with capwap image, you need a WLC, otherwise the AP is useless.
What I've read as well is that I need the EWC firmware image. That will be difficult to get without a support contract, right?
Just to highlight - not all of those APs can run EWC, some can only be subordinate (join to an EWC AP):
https://www.cisco.com/c/en/us/td/docs/wireless/controller/ewc/17-12/rel-notes/ewc-rn-17-12-x.html#Cisco_Concept.dita_4e686689-db5f-464b-8157-92abcfd40028
Only the Primary AP models can run the EWC controller software:
Cisco Catalyst 9115 Series
Cisco Catalyst 9117 Series
Cisco Catalyst 9120 Series
Cisco Catalyst 9124AXE/I/D
Cisco Catalyst 9130
Cisco Catalyst 9105AXI
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
@whyme
 WS-C3650-24PS-L is a switch not AP.  For Lab purpose, it is fine to buy old device like this.
wrong example, sorry ;D
