06-22-2023 01:59 PM
06-22-2023 02:06 PM
06-22-2023 03:51 PM
Thank you for your suggestion.
06-22-2023 03:17 PM
@alessandrodematos's answer is spot on.
Just to add one thing - if you're a confident coder, you can keep the networks separate (not templated) and perform bulk changes via the API.
06-22-2023 03:50 PM
Thank you for the suggestion but I am not very familiar with coding or using API. I think it's best for me to use the features provided within the Meraki dashboard.
