Users are facing latency issue while using google meet
majority of users are experiencing recurring latency issues during Google Meet sessions. We have observed that latency exceeds 300 ms during the initial minutes of calls, with occasional spikes reaching up to 1300 ms. Despite having traffic shaping rules in place specifically for Google Meet, the issue persists.
MR RF and traffic shaping-->
image.jpegMX traffic shaping rule
image.jpegMR Traffic shaping
MX traffic shaping-->
image.jpegMX Traffic Shaping
Browser Compatibility issue is also there, Connectivity issues are appearing specifically when using older versions of Google Chrome.
aleabrahao
Meraki Community All-Star
Don't you think reserving only 5 Mbps is too low? I believe that, depending on the number of users, this transfer rate is insufficient, especially if they are using video during the meeting.
Have you tried increasing the limit or removing this restriction?
Regarding the compatibility issue, there's not much we can do besides suggesting you update your browser or use a different one.
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
Agreed, I would try setting that to something like 10 or even 20 mbps temporarily and see if the problem goes away, also check your switch QOS settings that you are trusting those markings.
mloraditch
You specifically note the issues are coming from users with older versions of Chrome. If they don't come when using up-to-date versions then I think that answers your own question. Or did you mean something else?
If you found this post helpful, please give it a thumbs up. If my answer solves your problem please click Accept as Solution so others can benefit from it.
khalidbochajra
Community Member
Please, take a moment and look at this Reddit post for somebody who has the same issue that you're describing:
https://www.reddit.com/r/meraki/comments/pkhwbo/anyone_having_issues_with_google_meet_and_meraki/
Hope that would at least give you some insights on what's to do next.
