Users has unlimited up/down using WLC on different SSID
JohnDigby
I have a bunch of users that are on a separate SSID on a WLC that get max up/download speeds even though the QOS has been applied. All users that use the other SSID get 10mb max, and use the same QOS configuration as the others
Any advise on where else to look?????
Thanks in advance
Sandeep Choudhary
chekc if SSIDs have the same conifg except SSIDname and pre shared key ?
Thats the weird part, its only the SSID that is different, they both have the same Override Per-User Bandwidth Contracts setttings
Leo Laohoo
What firmware is the controller running on?
Its on 8.8.125.0, would the Anchor controller change the QOS if they have it set-up on thier?
