Using 1300 with Yagi
kthned
Level 5
Level 5
hi to all
I am stuck in a problem, we have a aironet 1300 series with yagi antenna we get the response but it was very hi i.e 1500 msec
Can any body tell me wat can i do to decrease the response time. as the distance to main branch is 5Km.
Please help me regarding this issue.
scottmac
Level 11
Level 11
It's likely to be an interference issue. The interference is (probably) causing a high nuber of re-transmits.
Try lowering your RTS threshold.
Try other channels.
Verify that your antennas are optimally aimed.
If none of the above works, you may need to switch to a parabolic (dish) antenna(s) - they have a tighter pattern for transmit and receive and perhaps you can exclude or reduce the interfering signal.
Good Luck
Scott
