Using a 3560 with 526 Controller and 521 AP's
Kevin Melton
Level 2
Level 2
I recently purchased a 526 WMAC as well as 6 521 Controller Mode AP's for a Customer. These devices will be used in a Convention Center adjacent to the existing property.
This convention Center will also be wired for about 80 cabled LAN drops. I have sold two 48 port 3560 switches to the customer.
The default SBCS switches would have been a UC500 with two companion CE500 switches. I do not have the ability to use those now since I ordered the 3560 switches.
All of these devices will be managed within an existing Management VLAN. All of the guests whom attend the Convention Center will be within an existing guest VLAN.
I wanted to use CCA to configure and manage the AP's, especially the RRM functionality. Is this possible to do if I plug the 526 and then in turn the AP's into the 3560 switches?
didyap
Level 6
Level 6
Follow the Installation and Configuration Guide for the CCA which will help you :
http://www.cisco.com/en/US/docs/security/nac/appliance/configuration_guide/412/cam/412_cam_book.html
the installation and Configuration Guide that you have referenced references the UC500 switch and the CE500 switches, not the 3560's that I have here. That is why I wrote this post to begin with....
