Using a BR350 and AP350 to link 2 buildings together?
darron
Can I use a br350 and a ap350 to link 2 buildings together or do I need to use a br350 and a wgb350 to link them together? Whats modes should the radio's be set in if the ap and the br work together? Thanks in advance!
amitubale
You will need 2 wirless bridges to link 2 buildings.
You could use both br350s or wgb350 depending on other specifications(distance, etc)
On the BR350's the radios should be set on "Root Bridge" on both the bridges.
An AP 350 cannot be used since it does not have any bridging function.
So, it would be possible to link a wgb to a br about 2-4 miles away?
I would recommend that you use a Non-Root BR to connect to the other side,and then connect the WGB, this will give you a more stable,reliable and scalable solution, over the time and that would really be a good investment from the future perspective.
