Using bridge antenna
alberto
Community Member
I want to cover a large extension. So I need a omnidireccional antenna. I'm thinking in Air-ant2506, but I see that it is used as a bridge. Can I use this antenna if I don't want to use it as a bridge?
btillery
Yes, you can use the AIR-ANT2506 in a client <-> AP application. The AIR-ANT2506 is designed as a mast mount antenna implying external use in a bridge <-> application. The AIR-ANT1728 is a ceiling mount antenna with similar RF properties designed for indoor use.
You can find out more here: http://www.cisco.com/en/US/products/hw/wireless/ps469/products_data_sheet09186a008008883b.html
