Using C9105AXI-C under C9105AXI-EWC-C
Dear all,
We have C9105AXI-EWC-C in our stock. we are planing to purchase C9105AXI-C of 15 unit.
Plan is we want to use C9105AXI-EWC-C as a controller and 15 unit of C9105AXI-C access points under this EWC Controller.
Is this solution possible and okay. Will all features work properly (like wifi roaming and so on) Please suggest.
2 Accepted Solutions
marce1000
  - That should work if the EWC controller AP uses a compatible software version for the
     C9105AXI-C access points  ;  which will usually be the case ; check https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
    However today deploying EWC is no longer the best solution https://www.cisco.com/c/en/us/products/collateral/wireless/embedded-wireless-controller-catalyst-access-points/wireless-ewc-access-point-eol.html
    Better go for a native 9800 controller , you can for instance download and deploy the 9800 virtual controller for free!
  M.
Saikat Nandy
This solution is possible. But remember that EWC has been marked EOL - https://www.cisco.com/c/en/us/products/collateral/wireless/embedded-wireless-controller-catalyst-access-points/wireless-ewc-access-point-eol.html. So if you are looking for long-run solution then controller based deployment is the one you should look for. 9800-CL can be used as well, if needed. Since in EWC, AP acts like a controller there will be few feature limitation, example SNMP and will run on limited resources.
10 Replies 10
marce1000
  M.
1038222951
it will be ok
Leo Laohoo
How about Cisco vWLC?  At least it is free.
  -  @Leo Laohoo           Aireos vWLC is old stuff Leo...
  M.
"old stuff" is miles better than EWC.
  - @Leo Laohoo   Sorry, but I can't agree fully here ;  it might be better then EWC, but these modern APs are targeted for the
                             9800 platforms , including follow-up with bugfixes , new features,...
                              (cisco  has stopped support for Aireos  e.g. ,it's use is strongly discouraged )
 M.
9800CL is another free option.
Saikat Nandy
As we are looking for budget friendly solution, can we use 14-15 pc of CBW150AX access point.
As i heard is can be managed from CBD for free, without any licensing.
Can a total of 15 APs in a office, be managed from a single dashboard and all necessary features will work properly ?
please suggest !
  - @imranulhoque2020           >...As i heard is can be managed from CBD for free, without any licensing.
                                       Ref :  https://www.cisco.com/c/en/us/products/collateral/wireless/business-100-series-access-points/business-access-point-ds.html
                                        >...Optional multisite remote management is available through the Cisco Business Dashboard, which is free to use for up to 25 devices
  M.
