Using DHCP Option 60 with Aironet APs
elsamadrigal
I'm trying to configure Aironet 1000 series and Aironet 1130 series APs to talk to a wireless controller card inside a 2811 ISR. I have a Catalyst 3550 L2/L3 Switch between my APs and the 2811. So far the Aironet 1000 series found the wireless controller successfully. The following is the current configuration for the 3550 DHCP pool:
ip dhcp pool WLAN_CM
network 172.27.2.0 255.255.255.0
option 60 ascii "Airespace.AP1200"
default-router 172.27.2.1
option 43 ascii "172.27.3.12"
I would like to add another option 60 statement to be able to connect the Aironet 1130 AP. Would this configuration work?:
option 60 ascii "Cisco AP c1130"
I will try shortly in the lab. I am not sure if I need to create another DHCP pool entirely dedicated for the 1130.
Any input will be much appreciated.
o-ziltener
Hello
why do you use option 60?
From my view, the AP needs just to know option 43 to find the controller, but the problem is that the airespace-ap wanna have option 43 in ascii and ios-ap in lwapp mode wanna have the option in hex.
best regards
Oliver
