Using PwrInj3 power injector with Aironet 1815i
mmostafa
can I user Cisco PWRINJ3 to power up a Cisco Aironet 1815i, I already have one but the AP is not powering up. is it not compatible? and why?
thanks,
I'm afraid the AIR-PWRINJ3 is pre-802.3af so will not be able to power the AP.
Seb Rupik
Hi there,
The 1815i datasheet states that is requires a 802.3af/at compliant power source. You will need a AIR-PWRINJ5= or AIR-PWRINJ6= .
https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1815-series-access-points/datasheet-c78-738243.html
cheers,
Seb.
there is no work around to use the PWRINJ3 with it ?
