Using Radius to determine vlan assignment
rattebery1
Visitor
In our schools we have multiple vlans for staff and students which are filtered.  We also have an unfiltered vlan for administrators.  Currently we are using 2 ssids to select which vlan the user will be assigned.
ssid-01 [WPA + WPA2][Auth(PSK)] filtered access using interface groups to pool multiple vlans.
ssid-02 [WPA2][Auth(802.1X)]unfiltered access using a single vlan.
We would would like to have all staff and students use Auth 802.1x using a single ssid for everyone.  For the filtered access (majority of clients) we will be pooling several vlans and for the unfiltered clients we will have 1 vlan.  The vlan assignment will be based on the users Active Directory group.
Example:
Unfiltered vlans 202, 203 and 204
Filtered vlan 300
Radius will select vlan 202 for users in filtered group and vlan 300 for users in unfiltered group.
How do I configure the WLAN ssid so that it will use the pooled address for the filtered group and a single vlan for the unfiltered group using a single ssid?
Francesco Molino
In terms of ssid, you need to setup dot1x authentication, choose your radius server configured on the ssid security tab/aaa tab. On the advanced tab, you have to check aaa override and nac state as radius nac.
All the rest, I mean dynamic vlan assignment will be done on the radius server.
Check that post:
https://supportforums.cisco.com/discussion/13285176/multiple-vlans-assignment-cisco-ise14-single-ssid-over-local-mode-lwap
If you want to allow everyone on vlan 300, then you'll need to select the local layer 3 vlan 300 interface. Create also the interface vlan 202  globally..
Does that answer your question?
PS: please don't forget to rate and mark as correct answer if this answered your question
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
rattebery1
Visitor
In my original post the example was backwards corrected example is
Filtered vlans 202, 203 and 204...
Unfiltered vlan 300
Depending on the size of the school we will pool additional vlan's /23 for the filtered users.  Only a few users will have the unfiltered access on vlan 300.
In the document https://supportforums.cisco.com/discussion/13290276/using-radius-determine-vlan-assignment it states The AAA override with interface group is not supported.  If this is the case how will the pooling of vlan's be assigned for the filtered users?
AAA override with interface group is supported:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/8-2/config-guide/b_cg82/b_cg82_chapter_0111110.html
PS: Please don't forget to rate and mark as correct answer if this answered your question
Francesco
