Using Splitter - Urgent
n-khouri
Community Member
I can not find enough info to explain the use of splitter , I have this scenario I hope someeone can advise .
I have a small building with one floor and a roof ,
Doing the site survey with different positiong of the AP , I can cover the floor but nothing on the roof , Can I use splitter with one antenna in the floor and another on the roof (20 meter away) , note that number of user in 4 for the floor and 1 for the roof .
tlchant
Should not be a proble as long as you choose a good splitter and RF cable. LMR400 at least. The splitter will give you an insertion loss of 0.5 dB at 2500 MHz. Your antennas I am assuming are omni directional with at lest 3-5 dBi gain. As long as your cable runs are kept to a minimum it should be fine.
shh5455
Level 7
Level 7
Also make sure you adjust your RTS thresholds as you will have hidden node problems since the clients on the roof can't see the clients under the roof.
n-khouri
Community Member
Thanks man but you got me confused , do u mean
the hidden node can't communicate with the other nodes ? Can I refer me to some references for splitter use and considerations .
