Valid Trust Anchor - certificate issue?
zappo0305
Im having problem with windows 7 certificate error as shown on this site:
http://www.wiredprairie.us/blog/index.php/archives/906
Ive look around for answer, but there's only found the workaround. Has anyone face this problem or have the solution?
Cheers,
Scott Fella
What authentication method are you using. I have seem this when you setup the radius for PEAP and the client is setup to use certificate.
-Scott
maldehne
You should have the certificate for the root CA issuing the server side certificate installed on your pc to get rid of this.
Also you might uncheck the validate CA certificate option on the WLAN profile configured on your windows supplicant.
