Verify C9800 - Flexible Radio Assignment Opertions in Catalyst Center
ciscoprolin
Dear All,
after hesitating for a long time we finally reenabled FRA on our new C9800 platform 17.9.5 and so far it looks good.
Question: Does anyone know how we can best verify the FRA operations ? With the CLI command "show ap fra" we just see the current picture but we'd like to see how the radios changed after enabling FRA compared to before.
Are there any useful reports available in Catalyst Center 2.3.5 or later ?
Thanks very much.
Rasika Nayanajith
You can use DNAC Assurance heat maps (Assurance -> AI Network Analytics -> Network Heat Map). One KPI to look at 'channel change count' and see if you see a clear difference before FRA and after FRA enable.
Typically look at 1 month stats and then you will see if any clear indication of each AP channel change count.
Rasika
*** Pls rate all useful responses ***
Rasika Nayanajith
Rasika
