Virtual page redirection issue - VWLC
Prasan Venky
Level 7
Level 7
Hello All,
I am using ISE for external web authentication. Once client enter the UN and PWD in the ISE guest portal, the client must redirect to 1.1.1.1 that is the local web page. But i get a blank page..? And also if i use local web page for the redirection also it is not working ..?
Any idea..
KVS
aqjaved
Level 6
Level 6
Symptoms or Issue
The URL redirection page in the client machine's browser does  not correctly guide the end user to the appropriate URL.
Conditions:
This issue is most applicable to 802.1X authentication sessions  that require URL redirection and Guest Centralized Web Authentication  (CWA) login sessions.
Possible Causes:
There are multiple causes for this issue. See the Resolutions descriptions that follow for explanation.
Please check the below link for URL Redirection Resolutions:
http://www.cisco.com/en/US/docs/security/ise/1.1/user_guide/ise_troubleshooting.pdf
Abhishek Abhishek
Possible Causes The switch is missing the ip http server and/or ip http secure-server command.
Resolution Verify and (if necessary) adjust the configuration on the switch. Possible Causes The switch is missing the ip http server and/or ip http secure-server command.
