Showing results forĀ
Search instead forĀ
Did you mean:Ā
Virtual Wireless Lan Controller configuration
MUHAMMED SHAFI
Level 2
Level 2
Dear All,
I have Virtual Wirelss lan controlle 7.0 and also have 1600,3600 cisco access point i want configure three SSID in vWLC or AP  like (STAFF,GUEST,MANAGER)
how to i can configure three SSID in AP or vWLC .what i have configure switch side like vlan
if you have any doc or configuration details please help me
i am waiting for your replay
Muhammed
Rasika Nayanajith
Looks like vWLC 7.0 is not publicly available release (I can see douments for vWLC 7.3.x onwards)
Here is one deployment guide I can find from cisco.com
http://www.cisco.com/en/US/products/ps12723/products_tech_note09186a0080bd2d04.shtml
Regarding AP models for 1600 you required  minimum 7.4.100.0 code. 3600 required minimum 7.1.91.0
Refere the below compatibility matrix for that
So bottom line is you require vWLC 7.4 to support these AP models
Rasika
**** Pls rate all useful responses ****
kaaftab
Level 9
Level 9
Kindly check the following link for wireless deployment (ios compatibility Matrix)
                 http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
