Virtual Wireless LAN Controller tftp error 10054
it
Visitor
Hello
I got virtual Wireless LAN Controller installed with version 8.1.102 on VMWare ESXi 5.1 running on IBM x3550M4 and the network card is E1000
Want to download via tftp the update to 8.3 but fails after 91%.
The following error comes. pls suggest.
Connection received from 172.22.8.250 on port 7700 [31/10 13:10:14.647]
Read request for file </AIR-CTVM-K9-8-3-102-0.aes>. Mode octet [31/10 13:10:14.648]
Using local port 64406 [31/10 13:10:14.657]
File <\AIR-CTVM-K9-8-3-102-0.aes> : error 10054 in system call recv An existing connection was forcibly closed by the remote host. [31/10 13:14:09.219]
I tried with FTP it doesn't work the network card seem's to crash for a little while because of the download failure.
Any clue?
7 Replies 7
Scott Fella
Try to perform this from the wired network. Also if you still have issues, see if you can backup the config via TFTP or FTP. Make sure your FW on your machine is not blocking.
-Scott
*** Please rare helpful posts ***
-Scott
Also make sure you check the MD5 hash on the image.
-Scott
-Scott
I did and the check is successful
Upgrade to v8.2.130.0 then to v8.3 and see how that goes.
-Scott
-Scott
hi Scott
I'm on the wired network on same subnet than the WLC and no FW between us.
Try to backup the config to tftp/ftp and verify that works first.
-Scott
-Scott
JulioRuiz6867
Community Member
Hi sir
can i make one question?
Did you resolve this problem?
could you say me how did you resolve it?
