vlan 1 managment not vlan 0 untagged in wlc
Dhikra Marghli
Level 5
Level 5
Hello
I have VLAN 0 vlan managment in wlc. vlan untagged ..
so i want vlan 0 to be vlan 1 managment in wlc ...?? when i put command
config interface vlan managment 1 ===> wlc blocked and not allow me to save config !!
i need all cammand that allow vlan 0 to vlan 1 managment like the previous configuration
so  wait a reply from expert wirless that give me a answer
thanks in advance
5 Accepted Solutions
Here is how it works.... if you are using vlan 1 in your switch infrastructure, then that vlan is always untagged by default within the software.  So that would mean that your controller if using vlan 1 for management just need to add the vlan to the trunk as by default it knows vlan 1 is untagged.
-Scott
If you are using an AireOS controller, then the management is 0. A 9800, is like a switch so it knows that vlan 1 is always untagged.
-Scott
Well it seems like the management interface can not be untagged:
Management interface VLAN tag
Cisco recommends using VLAN tagging for the management interface of the WLC. To configure the wireless management traffic to be tagged, just make sure there is no native VLAN command under the trunk configuration on the port/LAG. For example:
interface GigabitEthernet2
 switchport trunk allowed vlan 201,210,211
 switchport mode trunk
where 201 is the wireless management interface VLAN and 210 and 211 are the client VLANs. Ensure that the corresponding VLAN is allowed on the switch port as well and is tagged by the trunk (nonnative VLAN). In the above configuration, the assumption is that the native VLAN (by default this is VLAN 1) is not used.
-Scott
Here is the command to configure vlan on mgmt interface: config interface vlan management 1
Switchport config should look like:
interface Gig x
Switchport mode trunk
Switchport trunk allowed vlan 1, 7
But above config will not work because vlan 1 is untagged.
Best case would be: Plan a different vlan for wlc mgmt and assign to WLC and swicthport.
Dont forget to rate helpful posts
if you assign VLAN 0 on mgmt interface of the wlc then it should work.
Switch config will look like this:
interface ethernet 1/34
switchport trunk allowed vlan 1,7
Regarding Internet issue:
check if you can get connectivity between switch and firewall ? if not then resolve it first.
Looks to me is alike a routing issue not wireless.
15 Replies 15
Scott Fella
Vlan 1 is always untagged.  You need to define a different vlan.
-Scott
NO  , because the configuration initial is vlan 1 : vlan mangement not vlan 0 !!
so I want vlan 1 as vlan mangment !!
how i can make it as before !!
So please ,  i want a help for  vlan managment wlc cisco ::
thanks in advance
If you want vlan 1 as management, then your management vlan is tagged for 0.
-Scott
First i configure in switch :
interface g1/0/3  :**** conncted to wlc )
switchport trunk native vlan 0 ??? that allow me configuration vlan 1 in wlc !! or not !!  VLAN 1 : vlan for access point
Please , Scott can you explain me to understand !!
thanks in advance
-Scott
-Scott
interface GigabitEthernet1/0/43
thsi configuration in switch 9200 but      when i put in wlc this command :   config interface vlan managment 1
the wlc not allow me to save this command and is bloked !!!
it is my problem about vlan 0 to vlan 1 !!!
so if i  changed  this configuration in switch that allow me configure vlan 1 in wlc !!!??  this configuration in switch is correct or not !!!
i wait a reply and a solution for this problem
thanks in advance
Post your controller interface config also.
This switch port config basically means that vlan 1 is untagged and vlan 7 is tagged
-Scott
-Scott
Ok i unterstand You ... thanks to reply me
But  i want a command that i can configure in controller Cisco   interface management to be vlan 1 not vlan 0 ...!!!???
2) because before i configure in  wlc vlan 0 untagged ...it was vlan 1
3 ) before this configuration in Switch (now )
Switchport trunk allowed vlan 1 7
It was this configuration ( previous)
Switchport trunk native vlan 7
interface Gig x
 ok i understand   your reply ...BUT
initial state controller was connected before with Switch SMC:
config Switch SMC
switchport allowed vlan add 1 untagged
switchport native vlan 1
switchport allowed vlan add 1,7 tagged
configin  wlc with vlan 1 as vlan managment that allow pc laptop access to wlc 172.16.0.210 and  everything is fine ...
So  now , then customer wants wlc to connect to switch 9200. when I switch config SMC to switch 9200 .. wifi internet does not work either vlan 1 or vlan 0( wlc ) and you know they FW and router
so if the permutation does not work  , he wants wlc configuration  return as start
=====>  this is problem for permutation switch SMC with switch 9200 (  the goal of working ... in the permutation all switch to switch 9200, it is necessary that all works  fine .. but unfortunately  allow internet  wifi  wifi don't work !!!
NOW  :
Vlan 0  : addres ip : 172.16.0.210 with gatway 172.16.0.1/20  : 255.255.255.240
