Vlan based on SSID
NAVIN PARWAL
Level 7
Level 7
Folks,
         I have a requriement where the ACS server should send the vlan information based on SSID the user connected with.
Can I do this in ACS 5.0. I know I have to write a policy. But can not find a fild for SSID.
Any advice would be highly appreciated.
Parwal
Scott Fella
You can do that on ACS. For the SSID filtering you have to create an end station filter using the DNIS: *SSID
You have to then place that in your policy. You can also specify the vlan assignment.
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.2/user/guide/policy_mod.html
-Scott
If you want to do dynamic vlan assignment, you configure the vlan assignment in ACS under Policy Elements |
Authorization and Permissions | Network Access | Authorization Profiles
To specify the SSID:
Authorization and Permissions | Network Conditions | End Station Filters
-Scott
