Vmware ib bridged mode not getting IP in wlc 5508 with 7.5 Code
Angus Bishop
Dear folks ,
I am running WLC 5508 with 7.5.102.0 code .
My setup has webauth configured and is in a anchor - foreign setup .
My Vmware in bridged mode is not able to get ip . The host machine is getting the ip but the Vm in bridge mode is not getting the IP
Can anyone please tell me a rsoluion for this as i have a huge impact in my network
Angus
5 Replies 5
Stephen Rodriguez
sounds like you may need to disable the ip-mac binding.
config network ip-mac-binding disable
http://www.cisco.com/en/US/docs/wireless/controller/7.4/configuration/guides/system_management/config_system_management_chapter_01101.html
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Hi Stephen ,
Thanks for the fast reply .
I am not sure about the option i need to check .
Do i need to enable passive client option . is that a requiered configuration for connecting the bridged VMware clients .
Rgards
Angus
Scott Fella
Have you entered the command Steve posted and is it not working still?
-Scott
Angus Bishop
Dear scott.
I have not tried will try today and update .
I was going through some doc and seen that we need to enable passive client option . Is thos a requiered configuration..
Sent from Cisco Technical Support Android App
Bridging in VM never worked, you would have to NAT. If what Steve mentioned worked, then your good and everyone will know how to get this working. If it doesn't, well it's not news to any of us. You can search the forum and you will find others who have asked this same question for years. Passive clients does not help as I have tried that in the past.
-Scott
