Voice Roaming
NAVIN PARWAL
Level 7
Level 7
Folks,
          I have about 10 APs and 3 controllers and want to setup voice in my office. I went through the design guide, but I can not seem to find the things I need to do on the controller to make roaming work. Right know the phone calls and dropping when people move from one access point to another.
Any advice would be appreciated.
Parwal
Scott Fella
You need to setup mobility correctly first and then hopefully you have good coverage for voice.
http://www.cisco.com/en/US/docs/solutions/Enterprise/Mobility/emob41dg/ch2_Arch.html
-Scott
