vWLC Comments and Reviews?
raun.williams
Level 3
Level 3
     Just looking for feedback on the vWLC from anyone who's running it, compared to a 5508.  With the vWLC available, looking to migrate our existing FlexConnect sites to this setup to free up hardware controllers for the centralized requirements.  Just seems to make sense $$$ wise, the vWLC seems to be quite a bit cheaper then an adder license for the 5508, taking in account the Flex only requirement of the vWLC.
11 Replies 11
Amjad Abdullah
Ruan:
I did not personnaly use it. But you can give a look to the limitations it has and if you don't use those features that are not supported on vWLC then it should be good for you. You have probably read the doc already but posting it again does not harm.
Full vWLC doc:
https://supportforums.cisco.com/docs/DOC-26765
Amjad
Rating useful replies is more useful than saying "Thank you"
Thanks Amjad.  Yeah, I've taken a look at most things on it, just curious if any major 'caveats' other then those readily published.  Going to run a demo for awhile and move things over to it and see how it goes I think.  Though I'm wondering if the lack of replies indicates just a general lack of a user base, which is intersting..  I'm suprised Scott didn't have anything to comment on it actually, being a CDW guy.
It was Sunday. Scott has the right to be away from the forums during the weekend.
I think he'll be available today and can possibly shed some light.
Are you kidding me! I've had posts where that guy responds in less then a minute, he has set expectations!!!
lol
George Stefanick
We joke with Scott all the time .. He updates his Facebook "at dinner" I respond with hurry up we can respond to post !
Scott is in the mens room hurry up and post !
George Stefanick
To your point I don't know anyone with it in production .. Labs, yes ..
Just to clarify.. I know the vwlc can't be a guest controller, but it can be a foreign controller TO a guest anchor/controller for guest services, correct?
That is my understanding, yes.
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
Have you seen this link:
Features Not Supported on vWLC
  • Data DTLS
  • Cisco 600 Series OfficeExtend Access Points
  • Wireless rate limiting (bandwidth contract)
  • Internal DHCP server
  • Access points in local mode
  • Mobility/guest anchor
  • Multicast-unicast mode
  • IPv6
  • PMIPv6
  • WGB
  • VideoStream
  • Controller High Availability
  • Outdoor mesh access points (Outdoor AP with FlexConnect mode will work)
Yeah, but to be honest, wasn't sure if that meant IT acting as the guest anchor or attaching a wlan to a guest anchor.
As an update:  I setup th vWLC eval for testing and I can thankfully report that you can indeed attach to a guest controller.  Couldn't see why you wouldn't be able to do this, but certainly something that needed verifying from my point of view.  Need to finish configuring the controller and hope to move some test flex sites to it soon.
