VWLC - KVM Issue Network Interface
rcavezzale
Frequent Visitor
Frequent Visitor
Hi all,
We have a strange problem with network on the vWLC. already used KVM to virtualized unix vm without problem, when try to install the vWLC the VM not recognized the vNIC and show me the follow error:
ifconfig: SIOCGIFFLAGS: No such device
network configuration:
    <interface type='bridge'>
      <mac address='52:54:00:ba:77:78'/>
      <source bridge='br0'/>
      <vlan>
        <tag id='4094'/>
      </vlan>
      <virtualport type='openvswitch'>
        <parameters interfaceid='1e0230d5-86e5-4516-9f91-e2efd047ff74'/>
      </virtualport>
      <target dev='vnet0'/>
      <model type='virtio'/>
      <alias name='net0'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x0'/>
    </interface>
Could you help me? Best Regards
Philip D'Ath
Meraki Community All-Star
KVM is not supported.  Only VMWare is supported.
I don't think that cisco not support KVM because there is a how to to install it.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-1/KVM/b_CUWN8-1-vWLC-Deployment-Guide-using-LinuxKVM/installing_vwlc_and_kvm_with_ubuntu.html
However i solved my problem
Thanks for support.
  - If you solved , your problem ; courtesy to the community would inspire you to disclose HOW; and or to expand our knowledge (too).
M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Hi mark,
the resolution was simple.
I change release from 8.0.x.x to 8.3.102.0
