01-14-2016 08:39 AM - edited 07-05-2021 04:29 AM
Hello
I'm using a vWLC with a FlexConnect SSID and Web Authentication for the security.
I can connect to the SSID and get an IP address with all informations from local DHCP server. Unfortunately the automatic redirect to the Guest Web Page does not work. If I browse with the client to the address http://1.1.1.1 ,I get the Guest Web Page.
Do you have any idea, why the automatic redirection does not work.
vWLC version: 8.1.131.0
Best regards
Solved! Go to Solution.
01-15-2016 12:38 AM
Is DNS resolution working? e,g. Can you do a:
nslookup www.google.com
If that works, what happens when you browse to:
http://www.google.com/
01-14-2016 07:59 PM
Are you making an http request to trigger the redirection (as opposed to https)?
01-14-2016 10:32 PM
I tried http://1.1.1.1 and https://1.1.1.1
01-15-2016 12:38 AM
02-04-2016 07:05 AM
Hello
Thanks for your help. DNS was not working.
