WAP121 connecting issue with WPA only Client
I have a Cisco WAP121 with an SSID with both WPA2 and WPA.
I have 2 clients, one client is only WPA2 and 1 WPA only client.
The WPA2 client can connect with no issue, but the WPA can't.
After disabling WPA2 on SSID the WPA client can connect.
There is some configuration I'm missing?
Scott Fella
You shouldn't mix encryption types. For WPA you use TKIP for WPA2 you use AES. These are the standards. If you have both or a mix, clients get confused and they start having issues. Maybe create a separate SSID for each?
-Scott
The Documentation says that is possible to have both WPA/WPA2 checked.
Those clientes connects without problem with another cisco or motorola AP.
Well.... I'm just telling you what I know from expereince with the Cisco wireless devices.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
