WAP121 problem
davestevensuk
Community Member
I have 2x WAP 121s which have worked perfectly for 6+ months. Recently though wifi just disappears randomly, then reappears a little while later. During that time you can see the SSIDs, but entering the correct password will not connect you. I've tried tweaking a few settings as read in the forum, and also upgraded firmware to 1.0.6.2. Both are PoE from the switch, and when the problem occurs, the wifi & activity lights are flashing rapidly green. Sometimes you can fix it by power cycling one of the 121s, but that doesn't seem to be consistent.
Nothing has changed on the network, and what's more it only supports basic mobile clients, and no heavyweight audio/video etc.
Can anyone help troubleshoot further please, or indeed know what might be the problem?
David.
0 Replies 0
