WAP150
osama shalaby
Frequent Visitor
Frequent Visitor
Hi Gents
can WAP150 working with WLAN controller 3504.
Sandeep Choudhary
Bo it will not work with wlc 3504.
Dont forget to rate helpful posts
Thank you ...
Haydn Andrews
Bookmark this site:
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
its the Cisco wireless compatibility matrix, it shows the first and last software code supported by all WLCs and APs so you can confirm what will work with what
The WAP 150 is a controller-less AP so will not work with any controller
*****Help out other by using the rating system and marking answered questions as "Answered"*****
