wap200 wireless access point configuration
senzoselepe
Community Member
hi guys
I have a wap200 wireless access point configured and connected to the switch 2690 switch on vlan1, when I connect the wireless access points to the switch the port become disabled, is there a way to overcme this problem.
thank you
mnorwood
Hi Senzo.
Do you know the reason for the port becoming disabled? Can you run a "show int status err" on the switch and see if it give a reason for the port shutting down?
Matthew
