WAP4410N WDS not bridging
heywade723
Community Member
Hello  all,
I have two WAP4410N's that are about 30 feet apart in seperate buildings. I'm trying to bridge them and their wired networks together with no luck.
I would like each to also accept wireless connections.
They are both configured on the same subnet.
I've tried WAP2- personal on both with the same key on each with no luck.
I've tried WAP personal on both with the same key.
They are both on the same channel.
I set both to WDS AP mode,  no luck connecting.
They can see each other and obtain each others MAC address in the "Site Survey".  But I can not ping across the bridge.
I've tried one as an AP mode and one as a WDS mode,  and visa versa.
Do I set the AP Modes of each to WDS?
WIKIpedia says that WDS will not work with a dynamic key,  must use WEP.
Is that true?
Wikipedia says they can be different SSID's.
I will try WEP but not happy at all about it.
I wish the admin PDF's were more complete.
-heywade
0 Replies 0
