WBPN Wireless-n bridge for phone adapters will not configure
Hi. I just purchased a cisco wbpn wireless-n bridge to use with a cisco SPA-303 phone. In order to configure it, I have to use the web interface for the device, which supposedly has a default ip address of 192.168.1.254. (I have a Verizon router which does not support WPS). The IP address simply will not load. It constantly times out, no matter how many times you retry. Has the default ip address for this device been changed? If not, does anyone have any suggestions for configuring the device. The phone is useless to me without the wireless adapter. Thanks.
mvedel001
You have to go into your control panel & get into the network and internet connections (could be diff. wording depending on your OS) & then right click Local Area Connection > properties > TCP/IP IPv4 > Use the following IP address 192.168.1.2-253 (anything inbetween after you've determined whats available via CMD > Tracert "Your Router Addy")
Subnet 255 255 255 0 ; default gateway - nothing
then enter the IP address ;you have assigned into your browser
abwahid
Level 4
Level 4
1. You 1st have to change the network adaptor properties.
2. Put IP address in network adaptor properties any between 192.168.1.2 - 192.168.1.253
3. subnet mask 255.255.255.0
4. leave the gatway address field empty.
5. Go through below link for furhter guide.
https://supportforums.cisco.com/document/92746/cisco-wbpn-wireless-bridge-spa-phones-wifi-n
